1995 Ultra Classic Electra Glide
Old 11-03-2014, 08:32 PM
95sagoodyear's Avatar
95sagoodyear
95sagoodyear is offline
4th Gear
Default 1995 Ultra Classic Electra Glide
Hey guys and gals, Mike here. I just bought a 95 evo, and was wondering if you guys have ever had any experience with a squeak/squealing noise coming from towards the front when you let off of the accelerator? I came from a 2009 Road King, and I'm loving the sound and performance of the evo. Thanks
Old 11-03-2014, 08:41 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Welcome to the nut house!!!!!
You might have to be a bit more specific about the squeak/squeal.
Does it sound high up or down low. Front end or motor?
You might try shaking various parts to see if you can get them to squeak.
Old 11-03-2014, 09:12 PM
95sagoodyear
4th Gear
Thanks, Texas. The noise sounds down low, and I noticed today that it seems to do it when I relax on the throttle. It goes away if I hold the throttle steady, or if I increase the throttle. The bike only has 32,000 miles and some change, and I think it may have set up for a while. I'm really loving this bike, and it's already my baby. I just need to get her running right.
Old 11-03-2014, 09:38 PM
SeaZund's Avatar
SeaZund
SeaZund is offline
exhaust pipe loose, or maybe loose heat shield. Check that your flange nuts are snug.
Old 11-03-2014, 09:44 PM
texashillcountry
Dirt don't hurt
In your garage sit on the bike and push down on the handle bars.
Does it squeak then?
If so can you tell from where?
Old 11-03-2014, 10:13 PM
1CdnHD's Avatar
1CdnHD
1CdnHD is offline
Along with what has been mentioned, sometimes the upper engine mount stabilizer 'rod ends' can squeak/chirp, more so at idle tho when she's moving around a bit more.
Old 11-03-2014, 10:57 PM
D_gyver's Avatar
D_gyver
D_gyver is offline
you beat me to it I had one loose bolt on the mount it drove me nuts for two days till I found it
Old 11-04-2014, 07:49 AM
HGM's Avatar
HGM
HGM is offline
I'll third that.. I also wouldnt rule out the speedo drive if it happens only when rolling..
Old 11-06-2014, 05:59 PM
Hackd's Avatar
Hackd
Hackd is offline
Definitely check all the motor mounts. The front lower mount has a tendency to rot due to oil leaking on it during oil/filter changes.
Old 11-07-2014, 03:34 PM
95sagoodyear
4th Gear
Thanks for all the input. I have no idea where or what some of the parts you guys are talking about are....I've been looking for a good diagram to show me, and if anyone has a link, I'd really appreciate it. I'm not incapable of working on it, just unfamiliar with where the stuff is. Thanks again, Mike
Quick Reply: 1995 Ultra Classic Electra Glide
