FXR Wet Sumping
11-09-2014, 01:05 PM
FXR Wet Sumping
My FXRT has a wet sumping problem. Have replaced the check valve ball and spring, no difference. Any suggestions will be appreciated.
11-09-2014, 01:18 PM
Could be that it won't stop until the seat for the ball gets some attention.
11-09-2014, 04:54 PM
I changed the check ball and spring, tapped the seat using the old ball, and it did not seem to help much. I have noticed that some oil brands seem to seep into the sump more than others. Using Lucas oil treatment has dramatically reduced the problem for me.
11-10-2014, 03:50 PM
How much oil is in the system??
Remember to Not add oil till after you run it awhile....
Is it an S$S pump??
11-11-2014, 03:30 PM
let it run for 10 minutes or so and purge all out above the valve. it should stop after a cup or two. check level after its done and ride it more to keep from happening.
11-11-2014, 04:07 PM
Some S&S pumps from awhile back sump terribly...I have one...
9192daveyc
Oil Archive (no new posts)
04-25-2014 07:22 AM
xap6kov
Exhaust System Topics
02-15-2013 07:28 PM
shovel boy
Shovelhead
11-10-2010 10:20 PM
89 FXRS
EVO
24
10-26-2009 11:58 AM
Frowg
03-22-2007 01:23 PM
