Crashed...Now vibration
Old 11-21-2014, 03:58 PM
stevequad's Avatar
stevequad
stevequad is offline
Default Crashed...Now vibration
95 RK, but Big Sputhe Evo Motor, 106ci. I did a slide into the back of a car, and smashed everything from the passenger peg back, on the right side. Front motor mount was trashed, so a got a new one, and torqued to 22ft lbs. I was unable to ride due to a broken arm, but got on today for a first ride since I repaired it. (still waiting on painted bags)
Well, there is a serious vibration, just off of idle (no tach) it only last for a couple of hundred rpm's and seems pretty smooth at speed, and at idle. I am afraid the crank may have slipped some. It is an S&S crank and rods. Is there a way to diagnosis a crank problem with out a complete tear down? Any other ideas where this vibration is coming from?
Thanks for any ideas...
Steve
Old 11-21-2014, 04:32 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Steve, sorry to here about your incident and hope you are fine. S&S 107" here.
If the crank had slipped you would have far more serious vibes IMHO! It's far more likely that something simple is out of shape, such as the exhaust touching something it shouldn't. I suggest you start by checking your vehicle alignment (in other words that the engine/trans are correctly aligned on the rubber mounts), then check wheel alignment and work from there. Any significant impact can dislodge or distort things and it would be wise to confirm that your bike is fine and dandy. The processes of alignment are in the factory service manual, if you have one.
Old 11-21-2014, 05:09 PM
stevequad's Avatar
stevequad
The vibration happens with the bike stationary, in neutral with a slight rev, and while returning to idle as when coming to a stop. If I am sitting on it and rev just a little, it rattles my eyeballs. I do have a tru-track arm mounted to the right side frame, and to the transmission. I will check that along with the alignment. I do have the shop manual.
Thanks for your help.
Old 11-21-2014, 05:37 PM
br549A1's Avatar
br549A1
br549A1 is offline
My dyna does this and I've read similar posts from many that have a similar issue seems to be normal for us on some dynas. Is there a chance it's the new mount you got? Does it look or feel different then the one you took off. I think if something else got messed up in the crash you'd feel it driving more than the sitting still revving.
Old 11-21-2014, 05:51 PM
D_gyver's Avatar
D_gyver
D_gyver is offline
the vibration has always been there the new front mount is more rigid than your old one so you feel it more now.
Old 11-21-2014, 06:59 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Your motor is installed backwards if that is your red bike. Durrrrrr
Old 11-21-2014, 07:40 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,630 Likes on 843 Posts
WTF! I'm confused
Old 11-21-2014, 07:44 PM
Beemervet's Avatar
Beemervet
Beemervet is offline
Originally Posted by 1997bagger
WTF! I'm confused
psst......horn cover on the right side
Old 11-21-2014, 08:11 PM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
First Harley I have seen since the early Sportsters with the shifter on the right side. LOL
Old 11-21-2014, 08:37 PM
1997bagger's Avatar
1997bagger
psst........ noticed that, I'm still confused
Quick Reply: Crashed...Now vibration
