Console indicator lights
The bulbs are similar to Christmas lights. They plug in to a socket. Remove the socket from the panel and replace the bulb. I don't think you need to completely remove the panel, just enough to get to the bulbs. Make sure to cover the tank with a towel to prevent any scratching!
Common bulb from you local auto parts store. Don't forget to use some dielectric grease!
The bulb doesn't come out the bottom, they come out the top, leave the dash in place.. Pry off the cover for the lights and the bulbs sit in a rubber housing under it... Using tweezers remove and replace the bad bulb(s).. That's the way my 99 FXSTC was and I think your FL will be the same...
Ds
Ds
Dave
iwillfixthem4u
07-24-2012 10:19 PM
