New ride need help with an issue or two
Originally Posted by Tee⋁13541064
Where do you put your right hand when you're rolling and the grip is auto-twisting?
Only when you fall asleep. And trust me, I've nodded off at 70 mph....
The Harley-Davidson electronic cruise is one of the things The MoCo did right. Holds speed within 1mph on my 80" EVO. Resume, 'bump' to increase/decrease functions all work great.
Check for corrosion at the Set/Resume switch. It's just a small micro switch.
Check for corrosion at the stepper motor connection.
See if the on/off light is still working when the cruise is not. You could be tripping the breaker.
Unfortunately, the stepper motor has been obsoleted by The MoCo. If there is an issue with it, then you will need to source a used one from a salvage.
Again, I would start by checking the mini-toggle switch on the handlebar grip housing for corrosion or a bad connection.
Also check the idler cable. There is a spongy rubber spacer that prevents two contacts from completing a circuit. Rolling off the throttle compresses the spacer and the two contacts come together and deactivate the cruise. If the spacer is gone or permanently compressed, the circuit could be activating intermittently.
OK finally warmed up enough to ride a little and I noticed that the charging system was not acting quite right. Under 12v at idle and 16 cruising... I broke out the handy dandy volt meter and it was below 12v at idle but it was the top end that was scary... 17.5 at about 2800... I ordered a voltage regulator but you guys think a spike like that could cause cruise issues?
when the cruise quit on my '02 Ultra it was the micro switch on the throttle cable that kicks off the cruise when you twist the throttle off. it's along the neck in front of the tank on the right side. unplugged one wire from the switch and the cruise works again, still shuts off either with brake or clutch just not with the throttle.
