Dyna rubber mount replacement.
#41
#42
#43
There are a few places around here that do plasti-dip at very reasonable prices... I don't have anywhere to do anything like plasti-dip or paint in my garage.
#44
What? Just buy a can at the store and spray it on. Do it in your driveway or just cover the garage floor. I did my bars in 30 minutes, 5 coats. I let them sit an hour after before install. It dries fast. No sanding. Just clean and wipe it with alcohol first. Smooth surface is fine it goes right over chrome.
#45
#46
Lowes Home Depot Ace whatever you got they all sell it. Get the plastidip brand not the other. First coat you should see the original finish under still, second should cover it all. Then go three more but don't go too thick or it will drip. It levels and smooths when it dries and goes flat when dry. You can recoat once it's dry. If you don't like it peel and start over.
#47
#48
