91 ultra rebuild. Help needed. Again.!
Can anyone identify the Parts pictured. The 2 Alloy Spacers (4-off in total). 1/2" dia. holes
Rear Suspension Spacers??
The Electric Cable & Rubber Cover has Green Yellow & Black wires connected.
Just discovered that this Electric Cable & Rubber Cover is the old Oil Pressure Connection.
I had swapped this for an Oil Pressure Gauge a couple of years ago.
Bungo, I have a sneaky feeling the rubber boot is off an engine temperature or pressure sender, linked to your gauges. As for the spacers I am at a loss to imagine any 1/2" bolts that would need spacers! It is possible they are from both ends of each rear shock, but I don't see any in my parts book. Bit of a mystery!
spacers?
Looks like your swing arm spacers. Follw this link,
http://fiche.worldofpowersports.com/...0JIFFY%20STAND
The 4 Spacers are made of very light Alloy. Many thanks for reply. Bungo
I've been wrestling with this. I can only think of 2 spacers on my rear fender, on the top shock bolt, but that is only around 1/4" thick and I'm sure mine are steel. I can't think of any 1/2" bolts that are likely to use spacers!
