Ok help spend money!!
First off. I like the site a lot but for some reason it has been a real b tch to use. Pop ups. Click on one subject another comes up.so haven't used it much.
Been snowing like crazy here so ole 98 ultra been parked for 25 days
Going to jump on it and do a top end..
Have a spare set of cyls So what pistons do you guys like? How much overbore is safe on stock EVO jugs? Jim's gaskets? Not pulling bottom end out. Heads only guides and valves. Maybe cleanup cut. Compression Just finished my FXRP but that was on a budget. This bike I ride almost everyday . Already is carbed and ev27. Not a touring bike anymore now I have the 2012 ultra Wouldn't even touch it but typical oil now leaking out rear cyl. What pistons come coated?
Going to pull it a part in the next week so need to get ordering
Light touch up in ports but I know to keep volumes close. No polish. Just clean up like I do on intake manifolds
Ok spend away..........can't do a crate motor at this time or it would be done and over
Received 4,317 Likes
Go here http://www.hastingsmotorcycleparts.c...-Kit-TE400.htm
This is what I did. Plus a Andrews 46 cam
They also have lots of other options for the Evo.
Have fun!
Have fun!
I've read about other members suffering problems with pop-ups but have never suffered them myself. May be worth going to the 'Forum Issues' part of HDF, to see if there are any suggestions on avoiding them.
As for your bike I agree with THC that it is worth using a reputable shop to advise on CR and cam and to do your rebore and heads. No substitute for an expert input! I know we can come up with a home-made 'recipe', but ole Stormy will repay a bit of tender loving care, I'm sure!
Have fun!
Have fun!
stock bore 3.498 =81.69ci at .030 over your only gaining 1.4ci you wont even notice a gain in performance. its kind of sad they are calling it a big bore even worse people are buying it thinking it is.
Thanks everybody Boring is no problem I finally made a set of plates and bore and fit my own now. I also don't care about the next rebuild. Jugs are plentiful around here. But I don't want overheating either. So I guess .030 is were it's at. Wisco I use in other builds I do and Manley sever duty valves. I have heard good things about hillside. But turnaround time for me is a big deal. If I knew 2 weeks I could send out .I would do it as time is money. So time I dont have to do machine work......that i am slow at . I could be doing fab work on customer stuff getting paid. Why can't I be filthy rich ? Hey I got half of it. Lol. Oh a crate would be so much easer. Lol
That will do way more for you than merely boring out 30 thou and higher compression.
No not doing it for a big difference in power. Just want it sealed up good this time. Wanted to go the big motor route but time is not on my side rite now. I ride this one everyday now( other than the last 30 days lol) see if I can't swing a stroker next year. Nice to be busy but my stuff us last! Darn this site is a SOB now to use. I must have somethin wrong
