91 tour glide/ syn 3 ; bad idea?
Used syn 3 on all three changes and I also put on a newer outer primary gasket with a harley gasket.But the syn 3 just seems to seep more than normal. I feel I should drain the tranny and crank case again and use something else .Any recommendations what people are using these days?
Beary
Received 4,317 Likes
I'm not a proud person and enjoy learning new things, but I have never heard of Formula+ being a synthetic oil, nor can I find anything on the bottle or from Harley saying it is synthetic. Not saying you are wrong, I would just like to learn where you got that information.
Beary
Beary
formula+ is 50wt oil. Not synthetic at all. Here's an analysis done somewhere else. Redline makes a specific lil for evos non synthetic one for the primary and one for the gearbox.
Harley-Davidson Formula + ( Virgin oil analysis* Blackstone Labs)
Petroleum based. (Made by Citgo)
Ca 169
P 230
B 210
Zn - none
No other elemental additives.
Viscosity - within SAE 50 range.
Listed as a GL-1, does test out as a GL-3.
Published specs:
Specific Gravity: 0.857
Pounds per Gallon: 7.14
Viscosity, ASTM D 445,
cSt at 40°C: 168.04
cSt at 100°C: 20.10
Viscosity Index, ASTM D 2270: 139
Brookfield Viscosity, ASTM D 2983,
cP at -26°C - 28,800
cP at -40°C - n/m
Pour Point, ASTM D 97, °F (°C): -60 (-51)
Flash Point, ASTM D 92, °F (°C): 507 (264)
Ca 169
P 230
B 210
Zn - none
Published specs:
cSt at 40°C: 168.04
cSt at 100°C: 20.10
cP at -40°C - n/m
