Blew new Cometic head gasket
Blew New Cometic .030 head gasket. Compression test reviled 240 ft lbs on front piston at 12 turns wide open and 140 ft lbs on rear piston at the same. I am getting oil leaking at the rear of the cylinder and in the exhaust port. Also oil on the piston. Seems to be oil leaking everywhere. Here are some stats: 10 to one pistons, saved heads .050, Cometic .030 head gasket, Wood W6H cam. Question, does 240 ft lbs seem high and if not is their a gasket better suited for this type compression? Thanks for your help.
you went way to far with that cam your sitting at around 11.9:1 static and 11:1 corrected.
if you use .060 head gaskets and a w9 cam your still to high. your going to have to start over. either new flat top pistons witch would put you at 9:1 corrected or new heads put you at around 9.2:1 corrected.
yea, CR is WAY too high for that cam. get a new cam and bleed some cylinder pressure off.
you shaved the heads 50thou, used domed pistons, AND a .590" lift cam
you sure you didnt whack a valve too?
definitely check guides/seals too. stock evo heads arent even CLOSE to having enough clearance for .590" of lift. learned that from experience.
the sum of all parts != horsepower
his piston to valve clearance should be fine but if he didn't machine the valve guides and springs for that lift he probably smashed the seals. that's where the oil is coming from.
my motor has a .650 lift and my valves open at TDC is .220/.201 with domed pistons and .030 head gasket and around .020 off the heads and I have .120 piston to valve clearance on the exhaust and .086 on the intake
his valves open at TDC is .192/.178 that's not much more than stock.
Thank all for the replies. The piston is clear no sine of contact but I think you are correct about the valve seals. Do think it will work with a stock gasket .055" over the .030? I really want to save this build if I can. She had crazy power before failure.
if your compression is 230psi this should bring you down to a manageable level. whoever told you to take .050 off the heads was giving you bad advice.
