LED Turn Signal Lamps
Right. It is an easy solution and it is supposed to be one of the heavy duty solutions. The CD led lights I used were the ones that are turn, run, and brake lights. The turn signal is the normal 1156 socket and the run and brake lights run under the fender and are spliced into the tail light. I also changed to the later model Deluxe turn signal bar.
