Transmission pulley
Received 4,317 Likes
Motor has 9.5-1 pistons, .030 head gaskets, EV-27 cam.
Correction....if your running a 130/90/16 the approximate diameter is 25.7" so at a 2.92 ratio (32 tooth stock) at 70 you should be pulling around 2670 rpm and at 2.74 (34 tooth) 2516 rpm.not to much lugging I guess. But at 60 it would be little to low as 2142 rpm so for 55 mph your definitely gonna need 4 th gear....especially with that 27 cam.....
Doesn't sound worth it to me.
