What glue is recommended to repair cracks in plastic saddlebag backs?
Hopefully somebody's done this repair, I don't think it's uncommon....
I'm in the middle of getting parts ready to paint. Had a bad deep scratch on one of the bags. Asked a fella that works for a body shop for an idea how to fix it. We used some 3M stuff called panel adhesive. I had used it to fix a few parts some time ago but had forgotten. He uses it repair flexible bumper covers. It's tough to sand and shape but certainly strong enough.
It dang sure ain't cheap but works very well.
WP
WP
I had a crack develop in my left saddlebag on my '91 FLSTC. Started small and, as yours did, it grew. I ended up going to Menards (I'm in MN) and picked up the plastic welding kit that I believe others mentioned in their responses. It worked great. Included in the kit was a section of metal screen just like you would have in a screen door as well as some sections of plastic filler rods. The filler rods are just filler material but the screen will reinforce the repair area.
All you have to do is clean and scuff the repair area. Cut a section of the screen large enough to cover the repair area. Heat up the iron and press the screen with the iron into the melting plastic in the repair area. Cover the screen with more filler rods by gradually melting the rods with the iron until covered. You can dress the repair by sanding if you want. I left mine as is but tried to a least blend it or feather it out so that it's not too rough.
Mine has held and is way more ridged than it was previously.
Really easy fix that will only cost you about $20 and an hour or so of your time. Good Luck!
Have you ever used this product with HDPE plastic, which is indeed what the backs are made of? I've had trouble getting products to stick to that in the past.
Guys thanks for all this insight. I will try to get pics up tonight so you can see what I'm dealing with.
