85 Evo Wide Glide shifter linkage length?
Upgrading my 85 Low Rider to forward controls, I figured this is the best way to start with the shifter linkage length. I'm talking about the shaft between the shifter connection and the trans linkage.
I want to do a mock up before paint and powder coat so I' like to have the shaft here instead of blocking the bike up for a week or so without a kickstand.
Also, will I have to change any of the trans linkage parts?
Thanks gents
Thanks gents
Already have the forward controls, no shifter rod (from shifter pedal arm to trans linkage) or trans linkage included. I will be using the stock shifter linkage that's mounted to the trans if possible, I just didn't know if the trans mounted linkage was different for the forward controls than the mid shift trans mount linkage.
The arm that the shift pedal and the shifter rod bolts to is there and it's adjustable so I have some play room as far as length of the shift rod goes, I'm kind of just looking for a start point
I looked at the microfiche at Ronnies and it doesn't tell the length of the stock shifter rod, just shows a pic.
How long is your (shifter) rod?
Were you able to use your stock linkage off of the tranny or did you have to change out with parts in the kit"
