Allignment issues
Old 04-04-2015, 07:16 AM
glidein wide's Avatar
glidein wide
glidein wide is offline
Default Allignment issues
1986 FXWG: Does anyone have any issues lining the rear wheel to make the bike ride straight down the road? My adjusters are way off to make bike go straight and belt still seems to be running ok . Maybe the adjusters are fu***d,after market with numbers on them. If I make the numbers equal the bike does the crab walk.
Don't know if it has been in a crash, swing don't look bent.
Old 04-04-2015, 07:46 AM
factorybuilt's Avatar
factorybuilt
factorybuilt is offline
Do it the old school way. Measure each side from the swing arm bolts. I made my own device patterned off of the Harley tool. Easy and correct.
Old 04-04-2015, 08:31 AM
glidein wide
I have one, it's close, but something just not right it seems.
Old 04-04-2015, 10:54 AM
br549A1's Avatar
br549A1
br549A1 is offline
You should be able to get the rear tire straight using a homemade tool I use just a coat hanger and a small oring to slide to make sure both sides are the same from the axle to the hole in the Swingarm. If that is straight for you and it's still crab walking you should check the engine alignment. The only thing holding it straight is the front mount rear mount and the top stabilizer.
Old 04-04-2015, 11:02 AM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
Not a dyna. No rubber mounts on that machine.
Old 04-04-2015, 11:08 AM
br549A1's Avatar
br549A1
br549A1 is offline
Sorry about that, thought it said fxdwg. Check the rear tire see if it's worn off center and not evenly rounded from being ridden out of alignment before you straightened it.
Old 04-04-2015, 12:04 PM
tomfiii's Avatar
tomfiii
tomfiii is offline
Make sure front end is not tweaked or twisted as this will make wheel track off to side.
fmarti4922
06-30-2011 06:28 AM
Road King Kid
06-15-2010 04:43 PM
Crazy Canuck
09-09-2008 10:04 AM
wildside41
05-06-2007 02:27 AM
docsouce
08-13-2006 08:44 PM
Quick Reply: Allignment issues
