ultima ignition timing
If you static timed it already just try each of the 4 switch settings and use the one that works best. The best setting may not line up with the timing mark so it is probably a waste of time to dynamically time it to the mark. Unless the motor is bone stock of course.
If you want to tune it for racing or kick starting get one of these programming cables for $25 bucks: https://sites.google.com/site/vrusb2000i/
It works on Dynatek 2000i/2Ki ignitions too.
If you want the factory curves back you can click a button in Curvemaker to reactivate the switches. The factory curves are still in the ignition.
