Tranny usually hard to shift from 5th down to 4th?
1991 FLHTC, so this has been happening since I bought it last fall. I just did a fresh fluid change in transmission. I also had it done last fall when I bought it, only had maybe 3000 miles on it when I did it this past week.
When downshifting from 5th gear to 4th gear she sometimes likes to grind and then finally catches. I have gotten in the habit of letting rpm's drop to idle before trying to shift down into 4th. It's fine from there and no other gears give me issues, except for having trouble getting into neutral at times.
I should add that I just installed a new clutch cable. I have it adjusted with approx. 3/16" free play at the end of the lever. I did not adjust the clutch when I changed the Primary. Think that would help?
My clutch on this is very different than my metric. Meaning on this the clutch releases almost as soon as I release the lever. I start moving immediately. On my metric my clutch lever is almost all the way out before the clutch releases, and movement is rather delayed and a bit more controllable. Does this sound right for my model? Thoughts please?
I recommend you change your technique. By letting the engine revs drop to idle, one of the parts you want to engage during the gear change is rotating much faster than the other. That is why you hear the poor things grinding against each other and not completing the change!
Be kinder to them and raise engine speed, instead of lowering it, so that the engine speed is close to the speed it will rotate at once the gear is engaged. You should quickly find you are able to make silent changes like a pro!
I would also like to add that when I pulled the tranny drain plug there were a bunch of metal flakes on the magnet. Obviously doing it's job, but with only 3K miles on it since last oil change, is that normal? Dealer supposed did a 3 hole fluid change last august. Fluid wasn't black, but not very clean either with that low of miles on it. But since that was my 1st oil change myself I have nothing to compare it to. Wish I would have snapped a pic of what the fluid looked like before dumping it.
Best way I have found to adjust clutch is to loosen off cable ,remove derby cover, loosen off adjuster nut, turn allen head adjuster in while holding clutch lever and when lever goes to the halfway point off the bar lock the adjuster nut in place and adjust cable to preference. Once everything is tightened up pull the clutch lever a few times and it should feel good and you should see the clutch pack push outward disengaging. These instructions are for if you want the clutch to engage at half way point off bar. Adjust to preference for where you like it using same technique.
What about finding neutral? That can be tricky as well. I just got it back on the road last Friday and only have one good ride on it, maybe 60 miles. Sometimes I got it, sometimes I have to kill the motor then shift to neutral. Will adjusting the clutch help with that as well?
Thanks, sounds simple enough! It does seem to engage way too soon for my liking. It grabs so fast, makes me wonder if it is fully disengaged when trying to shift.
