Oil pressure
FWIW, after about 12 years on the road, my remanufactured EVO engine began to pass a lot of oil out the breather. Apparently, the little rubber flapper valves in the rocker boxes harden with age and heat, and no longer do their job.
When I dismantled the rocker boxes to replace the flapper valves, I also discovered that the rocker box gaskets had squeezed out of position around the breather chamber inside the rocker box. It wasn't leaking to the outside, but oil was able to pass from the rocker box directly into the breather chamber. New gaskets, flapper valves, and careful reassembly, and I get no more oil in the breather.
Oh, yeah, if the oil pressure light goes out when you start the bike and stays out, your oil pressure is fine.
Oil in the Breather Case?
Maybe I am way off base here, so let her fly if so. But isn't the crankcase breather tube routed to the back of the air filter housing in the oem configuration? Many here remove that and install a separate filter to keep that oil from being passed into the filter housing. This was done on my ride already when I bought it. I have one of the filters in the pic on mine mounted down on the side of the trans housing. The hose was still hanging from my carb with a plug in it. I removed that and the fitting and put a real plug right in the threaded hole where the fitting was. So to me it stands to reason that a small amount of oil would be normal, in the stock config.
The service manaul I had for the early EVO's stated..."the idle should be set just high enough to extinguish the OP warning light"...or some such verbiage. When I first started riding a Harley, I thought all the guys just revved-up their engine at signal lights to show-off their loud pipes. I learned that we revved them up to make the OP warning light stop blinking. My first experience with wanting an oil pressure gauge on my EVO was when the tech. told me that it would only scare me to death. It's practically a complete waste of money.
@Deputy I believe 1984 to 1992 Evo's had the breather come out the bottom, to which people will put a filter on. Like the chrome one shown. After 94 the breather comes out and is wrapped around into the back of air filter. That's the way it was explained to me by my local shop. I have excess oil coming out of mine and believe it is a worn out umbrella valve or flapper or whatever the name for it is. So I was wondering also at the time why my breather was down at bottom.
oil pres. or volume ?
I'm new to the forum and have a concern with a 96 Ultra with the 80 Evo. At an idle the oil pressure is only 2 to 4 psi and at 3000 rpm on the highway about 10 psi. The bike sat up for two years before I bought it. I immediately changed the oil with Penzoil 20w 50 and a new filter. This seems to be really low to me. Any advise or am I stressing ?
Roller and ball bearings require a high " volume " of oil as opposed to plain bearings that require a high oil pres. to assure no metal contact.
This being said i assume HD has included an oil dummy lamp to advise you that your motor is pretty much now junk if it comes on after 2000 rpm.?
I agree with all who advise that an oil pres. gauge will cause a lot of head scratching and consirns for no reason.
The oil pres. output from an EVO oil pump rates @ 12-35 lbs. at approx. 2000 rpm. The pres. at idle could be as low as 2 lbs. on up !
Hence the freaking out of all who install an oil pres. gauge .
One of these days i will fluid pres. test a HD oil pres. switch to see just where they are set to trip .
If anyone else has done this , please let us know .
