Exhaust Tick
#41
Sorry to hear about the case leak. If it ain't to bad wait till winter like the others said. However a valve job won't take that long and the riding season has only just begun....IMHO i would do the vale job now, you could wrench it all yourself and just bring the heads to your indy. Won't take long...
#42
one is find TDC on both front and rear compression stroke
two is once you are on TDC hold the rear wheel perfectly still
note - what you are hearing is the loss past the rings and thats normal - the compression numbers you posted are fine - you might have exhaust carbon under the valve seat face and valve seats them selves - that tends to cause a slight seepage and the marvil will eliminate that issue in a couple of tanks of fuel
what you also could use a leak down tester to use it would give you percentage of loss
have the guy tell you what the tick is first then see what happens - in the field we see more then an owner guessing
#43
John's advice is very good. Many years as a Chrysler mechanic, and Marvel Mystery Oil really does make a huge difference. On real heavy carbon buildup on the exhaust valves we would pour it directly into the carb holding the throttle plate open a bit to bring up the idle to 12- 1500 rpm slowly squeezing it in knocking the idle down a bit then saturating it till the motor almost stalls. Then shutting it down and let soak for a good hour. Start it back up and it takes a while for the oil to totally burn off but after that it's usually pretty darn clean and rubbing a hell of a lot smoother....
#44
#45
Just to follow up I've put on about 1000 miles since I started this thread. Had my indy check it out and run a leak down test. He couldn't pinpoint the tick, said the leak down test was marginal with a little leak down on the rear cylinder, but no sense in tearing into it now since we are planning on doing a rebuild this winter.
Took John's advice and ran put MMO in the gas tank for 5 tanks and still have the tick from the rear cylinder at idle, but it still runs good. A couple riding buddies say they only hear it at idle, but it sounds good when they are riding behind me.
Thanks for your help!
Tony
Tony
