I think i found my leak
  #31
Old 05-14-2015, 10:51 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
Hahahahaha
  #32
Old 05-15-2015, 04:31 AM
97 dyna lowrider's Avatar
97 dyna lowrider
97 dyna lowrider is offline
I wish mine had that info in it. I happend to stumble across this info while doing hours and hours of research before installing my belt drive.
  #33
Old 05-22-2015, 09:21 PM
misfitJason
Parts came in and I am shooting for Monday to get it done
  #34
Old 05-22-2015, 09:35 PM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
Just a reminder, all HD seals can be found at the autoparts store if you have the part number.... the crank seal is actually a GM wheel bearing seal.
  #35
Old 05-22-2015, 11:16 PM
RidemyEVO's Avatar
RidemyEVO
RidemyEVO is offline
This is some great info, which part number is it the parts guy would go by?
  #36
Old 05-22-2015, 11:18 PM
tmanbuckhunter
I don't recall... this was almost a year ago.
  #37
Old 05-23-2015, 05:01 AM
misfitJason
Cool. Valuable info
  #38
Old 05-24-2015, 08:53 PM
misfitJason
Started tearing her apart tonight to do the seal hopefully in the morning
  #39
Old 05-24-2015, 09:45 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,519 Likes on 2,862 Posts
with out the special tool it is easyer to install the seal and its not likely to bend if you install it tin out - nope never seen any difference in what way it goes - we bent the rules and install incorrect just to see what happens -- nothing
  #40
Old 05-25-2015, 08:26 AM
97 dyna lowrider
BDL states it must be installed with spring facing in. And from the looks of the pic your seal is in to far/deep. You can see a lip befor the seal? There should be no lip before the seal?? But When installed the seal should sit flush. With the crank case (the hole you are pressing it into. If it is to far in it will leak!!!.. This was my problem. Harley makes a special tool for this. The tool only allows the seal to be pressed in so far. Which is why the manual don't tell you how far in the seal needs to be. Harley assumes you have the tool. The only reason I know this is because I have a good relationship with the Harley dealer I go to and they told me how to seat the seal properly without the tool.
Quick Reply: I think i found my leak
