Lifter type tick between 2700-3000 rpm
I have a stock 1991 FLT with about 75,000 miles. I put in new HD lifters and new cam bearing about 3,000 miles ago. Experienced no noise in motor, but had fairly loud mufflers Runs fine, but put stock harley mufflers (very quite) on about 2,000 miles ago and now hear a distinct ticking (similar in sound and interval to loose pushrod) from about 2,700-,3,000 rpm. No other range of RPM. No unusual noise above 3,000 rpm. I have tested in neutral at 2700-3,000 rpm and found no exhaust leak. Engine has original non adjustable pushrods, thinking about installing adjustables to eliminate that possibility. Oil pressure is good. Any ideas of what this could be in the specific rpm range that I could check. Thanks!!
Lifters are non directional. Is it ticking when cruising with a light tip in of the throttle between 2700 and 3k? And does it go away under any load. If it's a slight tick don't worry about it. They will do that. If it gets louder and happens at all rpm ranges, then you might have an issue... Ride on......
The ticking at 2,700-3,000 rpm is under slight load, I can let off throttle and ticking goes away. Sounds like a push rod out of adjustment (I have non adjustables) or a lifter which has leaked down. But only at about 2,700-3,000 rpm. Cure might be to reinstall the original loud mufflers, no problem then (just kidding). Seems like I do remember HD manual saying lifters are non directional.
Adjustables are not the cure. I know people will argue that, but think about it, the guts of the lifter is nothing more than a piston in a cylinder, all the pushrod adjustment can do is change the position that piston runs at inside the lifter, it doesn`t take any backlash out of the system.
If the noise really bothers you, you might investigate the cam and pinion gear backlash, if it is excessive it will cause a tick that sounds like a lifter. Also a worn outer cam bushing will do the same thing.
