Evo died on freeway!!
Well…. sorry for the delay but wanted to get back to you guys just so you know the outcome, checked the cup behind the ignition and it was good and in the correct spot. Then i checked compression and had no compression on either cylinder!!! That lead me to taking the cam cover off and really see what was up. FOUND---- the pinion shaft was broken just behind the gear, pushed the broken side into my cam cover and chewed it all up. Not good! so now it's on to pulling the engine out and splitting cases for a new crank. Prob gonna go with a 89inch stroker crank from S&S. Thanks for all the help out there!!
How did that happen? Sounds like something wasn't done right.
