Fuel tank liner issue
Just thought I would share a recent experience that may helpothers. I installed a Pingelpetcock and found grey flakes around the petcock filter. After investigating further and from an Internetsearch apparently during some periods HD sealed the fuel tanks. My bike is a 1995 and there was a grey linerin the tank and it was flaking. Itappears the ethanol fuel may be the issue. Not sure of the facts, but I was fortunate to find just before a longtrip.
Received 4,317 Likes
Still in the process of cleaning and sealing. Used a small chain about the size used on a porch swing. I read a post in a forum where a guy used a large chain and when he shook the tank it dented from the inside out.
So I shook the chain to loosen the sealant and also scraped where possible with a long screw driver to loosen where bubbling. Next step was high air pressure. It appears most of the sealant is out.
I ordered a kit from J&P and this is the link from the manufacturer.
http://www.northernfactory.com/CHEMI..._LINERS_-_KITS
I had a piece of grey liner about the size of a USA quarter release on a 1998 Road King (fuel injected).
The grey liner piece was right next to a bracket within the tank.
It would get sucked towards the filter sock and starve the bike of fuel.
Released throttle, coasted and the piece would float away to return again a few minutes later when it blocked the filter sock.
It was rather easy to spot once home and the access panel was removed.
In my case i was able to locate, remove the USA quarter size piece and filter the fuel through a coffee filter.
No other part/liner piece was loose.
I would imagine that age and ethanol were involved.
The fuel injected fuel lines developed a leak about the same time.
All good for several years now.
My '94 has a yellow liner, and it's held up well.
When I cleaned the sediment out of it a few years back, I used a piece of brass chain I bought at the hardware store. It was heavy enough to knock the sediment loose, but not heavy enough to damage the tank. I went with brass as it's non-sparking-the service manual cautions you NOT to use steel ***** or chain for this reason.
I went with a piece of chain instead of lead shot because it's easier to get back out of the tank afterward.
Have you used it before?
Does it work better than POR-15 or Caswell?
The one part stuff is no good. Remember Kreem? That stuff was a nightmare! Long term, the only thing I know that holds up to todays fuels is the 2 part epoxies.
I have no experience with the por 15 product. YD
I agree, if you want to be done with it, use a 2 - part epoxy like the stuff texashillcountry mentioned from caswell. Of course after proper prep of the tank....
It isn't as thick as Caswell so it flows better but I have heard good and bad results with it.
I suspect the bad results were because of improper tank prep.
Good advice on the chain, guess I did not shake it too hard and am here to type.
