99 FLSTS Main Electrical Breaker
Anyone know where the main breaker is for a '99 FLSTS? The thing crapped out when I hit the starter... Complete electrical outage, so I know it's a breaker somewhere. Just can't seem to locate it. There are some 15A breakers under the seat, but the wiring is way too small a gage to be a main circuit. I'm guessing the main breaker would be ~30A or thereabouts.
Thanks!
Regards, Pete
Thanks!
Regards, Pete
Thanks Dan! Right were you said it was. A real pig to get at with a toolbox installed! Turned out it wasn't the trouble, but I'll know where to find it if the thing ever craps out.
Received 4,317 Likes
From your first post I'd guess a bad battery is your problem.
The screwy thing is that I had 12 volts at the battery. I Poked around with a multimeter (Key off) after Dan pointed me at the main breaker, and the bloody thing had power through it. When I turned the key on, battery voltage would drop to nothing. I thought my multimeter was hosed up, so I changed the 9VDC battery in that. Same thing... no difference.
Then I thought "Battery!". So I pulled all the circuit breakers to check them for continuity. With the breakers out the batttery voltage came back to 12+ volts. I re-installed the 1st breaker and got Neutral and oil light, but battery voltage sagged. The 2nd breaker brought the system to its knees!...
So new battery, put it all right... Pulled the VR plug to the stator and the thing is making 6 VAC on crank, and up to 48 VAC at 2000-3000 RPM. 13.68 VDC to the battery.
arizonapete
21
07-27-2006 10:39 AM
