Air Ride Rear shocks 1994 Road King...
Old 07-23-2015, 05:14 PM
ZachE's Avatar
ZachE
ZachE is offline
Default Air Ride Rear shocks 1994 Road King...
Hi,
I bought the bike last week, and have been going through her. The rear shocks aren't taking any air... I'm curious if the valve is different from a normal shrader? The front end took air fine with a little bicycle pump.
Thanks,
Zach
Old 07-23-2015, 05:39 PM
Kees's Avatar
Kees
Kees is offline
Originally Posted by ZachE
Hi,
Thanks,
Zach
Mine were leaking also which gave it a bouncing ride...I replaced them wit a set of Dyna shocks they work great even two up.
Old 07-23-2015, 09:11 PM
Crashone's Avatar
Crashone
Crashone is offline
Be careful how much pressure you put in the system. Doesn't take much. If the back ones are shot pull all of the air lines and shocks out and replace. I found a set of progressive 440's that seem to work well.
Old 07-24-2015, 06:02 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Hi Zach and welcome to HDF. That valve is a stock auto/bike type, nothing special. Your bike pump is quite good enough for use both front and rear. Start by checking the air lines and connectors, to make sure none of them are leaking. Your shocks are over 20 years old and to be blunt weren't exactly hot stuff when new, so don't be surprised if they are shot. As for replacements that is a long story only worth telling if you decide to change them!
Old 08-03-2015, 11:32 AM
ZachE's Avatar
ZachE
ZachE is offline
Thanks Guys,
I got the rear air shocks to pump up... Had the saddle bags off, and side panels off. I noticed that there was a stem extension on them that wasn't letting air in, that was the weird looking valve.
Thanks,
Zach
randall3424
03-24-2021 03:42 AM
Tangle Eye
32
06-09-2013 07:10 PM
reddog8145
11-22-2012 05:57 PM
brushbuster
09-12-2012 12:57 AM
Dakotazeb
03-18-2012 08:18 PM
Quick Reply: Air Ride Rear shocks 1994 Road King...
