91 ULTRA REBUILD. Nearly there!
Old 08-02-2015, 02:26 PM
BungoBill's Avatar
BungoBill
BungoBill is offline
Default 91 ULTRA REBUILD. Nearly there!
Was it over 2 years ago that I started this.Almost all bits together now just a bit of wiring & some nuts & bolts to be tightened. Motor fired up first time (indoors in my front room ) but I didnt run it for long for obvious reasons.!
Sounded good. One of the last things to be fixed is the tightening up of the new TrueTrack Swinging Arm spindle. As it has been such a long time since I fitted the Spindle I had to search for the new washers & nuts for the threaded ends. I only found 1 nut 2 washers & 2 spacers which corresponds with T.Track Illustration 20-19E . Why only 1 nut? I have contacted True Track who supplied the kit re. this but havent had a reply. Also ....what is the Torque setting for Pivot tightening. Bungo
Old 08-02-2015, 03:22 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Send some pics to us Yankees, please. ��
Old 08-02-2015, 04:13 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Talking
Perhaps you unwittingly found another use for that nut?! I suspect an old one will do, if you still have the parts. It's too long since I installed mine to recall if there were one or two of 'em. We Brits would also like pics!!!!!
Old 08-03-2015, 01:42 PM
BungoBill's Avatar
BungoBill
No problem Teev.
Old 08-03-2015, 02:00 PM
BungoBill's Avatar
BungoBill
Smile
Hi Graham,surprisingly it only comes with one nut. I have a couple of old S/A Pivot shafts with nuts attached so no problem. Will send pics soon or as soon as we get some decent sun here in Scotland! Worst summer on record almost.
I know you are having a great summer down South. I keep on looking at the old Ultra without the Tourpak topbox mounted and I and starting to see these extended panniers and fender in my dreams. Is there a cure for this?
Old 08-04-2015, 05:20 AM
grbrown's Avatar
grbrown
grbrown is offline
Talking
Weather has been very mixed and often different to the forecast! Only just above freezing here a few mornings ago. As for modifying your bike, there's no known cure, just go with the flow.....
chevdude
05-29-2017 07:19 PM
Hey Man
07-16-2016 05:28 PM
RockUltraClassic
Carburetor Related
06-14-2013 05:09 AM
TriGeezer
08-09-2012 10:34 PM
rleggs
03-09-2007 09:14 PM
Quick Reply: 91 ULTRA REBUILD. Nearly there!
