1994 Road King headlight is like a spot light...
Old 08-02-2015, 09:49 PM
ZachE's Avatar
ZachE
ZachE is offline
Default 1994 Road King headlight is like a spot light...
Hi,
I'm curious if the normal beam pattern is that of a spot light, where there is one bright spot down the road on a 94 Road king?
I took her for a spin tonight, and really didn't like the headlight. I'm curious if mine is an oddity, or is that standard equipment... It didn't light up the stripes in the road, just the center of my lane out to around a hundred feet.
Are there lens replacements that do a better job scattering light out to street signs and such... in addition to just changing bulbs?
Thanks,
Zach
Old 08-02-2015, 10:14 PM
Schex's Avatar
Schex
Schex is offline
Received 6,802 Likes on 1,756 Posts
If your headlight is like my oe '90 was, I couldn't tell if my lights where on when I rode with late model bikes,
Google "truck lite harley led", plenty people using them, I like them, also have the ltruck lite led passing lights.
They also draw less amps, easier on the charging system.
Old 08-03-2015, 09:41 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
Zach,
there is a wide variety of lighting available at the present, with the old incandescent variety (plus plenty of different reflector units), plus HID and LED, either of which can be bought as dedicated units, such as Trucklite, also as add-ons for existing reflectors. A lot has happened in the lighting field in recent years, so at least buy a current reflector, preferably one designated with an 'E', which should give good results.
There are stacks of threads across HDF on this subject, with the Touring section worth a visit, as they are keen on such things.
Old 08-03-2015, 12:10 PM
ZachE's Avatar
ZachE
ZachE is offline
Thanks Guys,
I've been searching around, and it looks like the upgrade is to LED or just E-Code headlamps.
The headlamp that is on it right now is a sylvania lens and reflector, so I'm going to give a Hella E-Code a try and see if that gives better light.
Thanks,
Zach
Old 08-03-2015, 01:14 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
It didn't come with a Sylvania lens. I've got a Trucklite on my bike, plus the Trucklite spots. It's really bright. I put the HD LED on the Sporty, as that was the only one available at the time. The difference is amazing.
Old 10-29-2015, 11:18 AM
ZachE's Avatar
ZachE
ZachE is offline
I ended up getting a HD factory H4 lens, which is the updated superceded part number. A lot better light on the road after that!
Zach
Old 10-29-2015, 05:08 PM
Joe_G's Avatar
Joe_G
Joe_G is offline
I installed a Truck Lite in my Road King and it was very happy with it. Here are some pics before and after:
Originally Posted by Joe_G
This is a great mod. Thanks OP for taking the time to post.
The Trucklight from DFS seems to fit my 95 Road King very well.
Orig. light
Trucklight
Low beam
High beam. Odd that the high beam is on the bottom.
Original light (no passing lights)
Truck light low beam
Trucklight high beam
Old 10-29-2015, 05:20 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
Im using a regular old Bosch motorcycle H-4 in mine and it really lights up the world at night. I tried a couple of others but the Bosch is by far the best I have tried. (cheap too)
Old 10-29-2015, 05:22 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
That is a heck of a difference!
Old 10-29-2015, 05:23 PM
Joe_G's Avatar
Joe_G
Joe_G is offline
NIGHT and DAY. I kept that light when I sold the bike and I put a 7" headlamp on my heritage springer so that I could use that light. It's so nice at night.
Quick Reply: 1994 Road King headlight is like a spot light...
