1999 EVO Heritage, carb, 40,000mi Buy / Not Buy
Local ad has an EVO 1999 Heritage, carb, $4500, 40,000 miles.
Original Owner. Ad says great condition, runs excellent, mechanically sound, long straight pipes, many long trips, never a problem, well taken care of, new Metzler 888 tires.
I'm ready to jump on it - it's even a color I like. (will put on quieter pipes)
But before I impulsively see it and buy it on the spot I want to ask you guys:
Is 16 years (1999) and 40,000 miles time for major maintenance or rebuild?
EVO questions to ask owner? (plus usual buying-used questions, signs of neglect, documentation).
If it starts up instantly from cold and runs normal for the length of a couple miles test ride, isn't that a pretty good sign of reasonable engine & trans condition?
Want it to be good enough condition (with a full maintenance) for 14-day solo ride next month Virginia, West Virginia, Georgia, Florida, return, camp sometimes. Want to ride a big twin instead of my Sportster.
And not break down. And keep it many years.
And not cost over $5000.
Thin wallet, price is very very right. My first big twin. Excited (calm down!)
Thanks for any advice.
Kayakeur Bud in Virginia
Aug 7, 2015
But, hey, its a used bike not a 2015 !
Aug 7, 2015
40K is not high miles if it hasn't been owned by a complete idiot who never changed the oil. Lifters are due to be changed at 50K and you'll probably want to fiddle with stuff while you are in there.
If it starts and runs OK it probably is OK as they are very simple bikes and trouble is usually pretty easy to spot.
Questions to ask:
Is it still running a stock cam?
Has it had the inner cam bearing upgrade?
Why are you selling it?
When was the last service/oil change?
Do you have a hot sister with loose morals?
Maybe not the last question....
If you look after it (change the oil every 5k miles and don't pull wheelies or thrash it from cold and don't do lot's of short journeys on it) it will easily do 100K miles.
Questions to ask:
Ask if the engine or tranny has ever been opened up for anything. Any records of maintenance? (Even Receipts)
is it leaking? if so, from where?
If it's got straight pipes either it has an S&S E or someone has worked on the stock carb.
Yes, it's a good indication if it idles and runs well that it is what he says. If you start it, put your fingers on the rear head fins. when they're warm you can take off. Pay attention to your mirror to see if you have blue smoke coming out on accel or decel. the valve guide seals may be shot if it sat for a really long time. (Yes, it's supposed to shake like that in the frame..hehe)
Try and get it for 4K. There aren't that many people out there looking for EVO's. Understand that you're going to have to open up the cam chest sooner than later and that's going to cost a few bucks. New lifters, (Not HD or screaming eagle) inner cam bearing. Optional: an andrews ev-27, S&S E, S&S steel breather gear, Andrews adjustable push rods, Jims or S&S lifters and a reasonable exhaust. hehe it adds up QUICK!
Happy motoring!
Happy motoring!
Bottom line, it's used. You may or may not have a problem. If you are going to take a trip shortly after you buy it, make sure you have the funds to tow it from your furthest point of your trip back to home and or have the funds for repairs while on the road.
If you can only afford the bike, roll the dice and go on your trip anyway. I've done things in life like that, you only live once don't let it pass you by.
Sounds like a fair deal if it appears to be in good condition. Also think about common sense, he may or may not tell you the truth about anything that may be bad on it.
Worse case, you by the bike for 4K, the engine totally goes south, for another 4K you could probably replace the engine and still have less money invested than a new Sporster.
Received 4,317 Likes
Questions to ask:
Questions to ask:
But before I impulsively see it and buy it on the spot - which may be a good idea at $4500 - I want to ask you guys:
Aug 7, 2015
fwiw: pessimist me notes new tires nice but may mean old ones very old, and
40,000mi in 16 years is only 2,500 miles a year, probably many periods of time idle in storage.
Aug 7, 2015
Probably this: http://washingtondc.craigslist.org/n...152997503.html
The only concerns are 'some dings'. Where? Tank? Fenders? Sheet metal is expensive. Matching paint is expensive. What one dude calls a 'ding' another may call a 'dent'.
