stock exhaust compatability?
A nice 2 into 1 maybe
WP
This is just a reference that might be correct. He says no shipping but if he get no response Well Might be worth a try
02 sensors can be plugged too
https://www.hdforums.com/forum/softa...5-softail.html
Received 4,317 Likes
At least I don't think I have the mounting bar.
You may need to cut them to an equivalent length, but it would be just the same.
However, general opinion is that with 2 into 2 shorties, it's better performance to have a cross over pipe.
The cross-over pipe is certainly well worth retaining. BSA discovered this back in the '60s IIRC and incorporated them on all their twins, which the rest of the manufacturers soon copied, to this day. Gives improved low/mid range torque.
So, I ended up going the cheap route. I kept the exhaust that the bike came with, which I ended up cutting. Then, I got some OEM muffers for $30, and bolted them up. I had to make my own mounting brackets, which was pretty easy. I cut the original heat shields too, and put them on the down pipes. Sounds and runs pretty good. Picture is below.
