oil leak by primary....
Old 08-28-2015, 08:09 PM
Hackd's Avatar
Hackd
Hackd is offline
Originally Posted by texashillcountry
I would suggest you replace all the seals on the inner primary while you have it apart.
Yup. Goes with the territory. I seem to recall there was a good amount of red RTV that was used somewhere too. I could only go back into the shop once when the first wrench showed me what had happened (and the groove in the inner primary).
Old 09-01-2015, 08:51 AM
800screws's Avatar
800screws
800screws is offline
I cannot for the life of me get the clutch hub off. I had a steering wheel puller laying around but it's tight as hell and I really don't want to break anything. How hard is the hub supposed to be on the shaft. I even heated it and nothing
Old 09-01-2015, 11:32 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,681 Likes on 1,338 Posts
What year bike is that? You really need the right puller.
Old 09-01-2015, 11:41 AM
falconbrother's Avatar
falconbrother
falconbrother is offline
If you have the tapered main shaft that's par for the course.
Old 09-01-2015, 11:42 AM
800screws's Avatar
800screws
89....I have one coming.....doesn't seem like this is gonna do it.....too much stress for only 2 little bolts.
im going to upgrade to a 91 enclosed belt drive and a 91 6 speed builders kit.......
Old 09-01-2015, 06:32 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,784 Likes on 3,300 Posts
Originally Posted by 800screws
89....I have one coming.....doesn't seem like this is gonna do it.....too much stress for only 2 little bolts. im going to upgrade to a 91 enclosed belt drive and a 91 6 speed builders kit.......
You can actually make a puller with a piece of 1/4' STEEL PLATE, a drill press and 1 nut to fit the shaft of your current puller. this way you can utilize all 4 bolts on the hub...
Old 09-04-2015, 01:03 PM
800screws's Avatar
800screws
okay got to this point....do I have to do anything with the rotor? and the snap ring that holds the inner primary bearing in? after removing the 7 bolts it should come off?
Old 09-04-2015, 01:17 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
No, just remove all the bolts and it should come off.
Old 09-04-2015, 01:34 PM
800screws's Avatar
800screws
thanks.....nothing wants to just come off on this bike! lol.....
Gordon65
01-14-2019 07:02 PM
rkcmike63
09-20-2016 02:02 PM
Eunoterpsia
02-10-2016 11:17 AM
philmore81
EVO
11
07-01-2014 04:19 AM
ragrat64
Exhaust System Topics
08-17-2006 12:17 AM
Quick Reply: oil leak by primary....
