Alright, I got the bearing out. The rollers have a little bit of wear but they all seem to spin fine? I'll have some detailed pics here in a minute. Can I replace just the bearing or do I need to replace the whole assembly?
I will replace the whole assembly then... on to the clutch I guess. Anyone want to buy a kidney? Before I go pulling the clutch hub off, is there ANYTHING ELSE I need to check that is easier to do? Any other possible thing that could be causing these problems?
You don't have to pull the clutch hub to check the plates.
Well, I was going to do that with the thought in mind of going ahead and replacing it with a barnet hub if the spring plate is dead, but counting my money, and my chickens that haven't hatched yet, I'll probably just slap in the barnet plates that replace the spring plate... I like eating and everything.
