Scored a nice '84 FXRP today
You know the one...The slot wallows out and then the tab bends and the bike leans further and further over until it almost wants to fall over.
I fixed it on my '89 and my brothers '92 and a few others that came into the shop and I never had to mess with the kickstand again.
The boxes of parts were misc. covers, an extra primary cover, an extra cam cover, the floorboard set, a bunch of clutch cables, extra electrical side covers, extra tins (gas tank, fenders and dash stuff) an extra oil tank, a couple of sets of the rubber trim for the dash including the very had to locate rubber rings for around the gas filler neck. stock FXRP handle bars and risers, an HS42 Mikuni carb, a bunch of brake pads, an extra set of heads and barrels and a couple of Cometic gasket sets, a couple of axles....All of the things that I usually have to search for when I build an FXR.
There's a lot of cool stuff there and there are still a couple of small boxes that I haven't gotten around to opening yet.
Yeah, that's the oil bath chain setup, They are VERY hard to find in decent condition....This one is like new (Bike only has 22,000 original miles on it)
At some point I'll take the oil bath thing off and put an O-ring chain on there and either sell the setup or save it for an eventual complete OEM restoration.
Who knows?
I don't mind replacing the rear belt on an FXR, I've done so many of them that it only takes a couple of hours at the most, but the chain is certainly easier and faster.
It's part of the frame, the bracket in the photo is an OEM replacement one that has to be welded in after removing the original one.
Every one that I've done has been in the frame when I did the modification.
I just use a piece of scrap metal of the right thickness and shape it and weld the little bastard in, paint it and put the inner primary back on.
