No fire on rear cylinder
I'm no electrical diagnostician and I'm at my wits end...
Long story short; my rear cylinder quit firing while riding and I had to limp home on the front cylinder. Checked rear cylinder for spark and it was very weak, barely visible. Front cylinder was fat and bright in comparison. I replaced plugs, wires, and coil(Accell Super Coil, single fire), no change. Could the crankshaft sensor or ignition module be faulty? How to check?
Thanks in advance to anyone with helpful links or advice on what to check next.
Semper Fi!
1995 FLSTN Heritage Softail Special, 20k miles, Andrews EV-3 cam, Crane HI-4 Ignition module
Semper Fi!
Received 19,625 Likes
'95 FLSTN Heritage Softail, 20,800 mi. Prev owner states he installed a "high performance ignition" and Andrews EV-3 cam. Also had a Crane single fire coil on it when I bought bike last August.
Thanks for the reply Scootertrash60.
Received 4,317 Likes
Did you check your connections and grounds like previously asked?
The problem is I don't know what electrical connections to check. I'm a bit of a bonehead when it comes to electronics. But I do have a volt-ohm meter and know basic electrical theory(don't touch red lead to negative, remove battery when working on electrical system)
I read somewhere that if the coil, plugs, and wires have been replaced, then either the ignition module or camshaft position sensor are likely culprits. Given the age of the bike I'd just as soon replace them both for peace of mind if nothing else and see what happens.
Thanks Tommy C
You should have 12v on the + side of your coil.
Crane HI 4 cone type ignitions are notorious for dropping a cylinder when they fail...since you had a crane coil, you may have one...just pull the "points" cover to see.
