Winter Project
Thanks guys, I wasn't sure on which cam to run so this is a big help. I heard the ev46 would be a good cam also. I have a local shop that does head work and has a really good reputation. As far as compression goes how much will going to 10.5.1 make a difference? Does anyone have any recommendations on the carb?
Hillside stage II heads, w6 cam, Wiseco 10:1and an S&S E will yield 90 lbs torque and 85 hp with great gas mileage and performance. Scott's done a lot of those.
Sorry, to get those numbers you will need a static comp of 10.5:1 if your going to use the w6 cam.
Originally Posted by Tee⋁14550578
Question for you:
What are your wheels and tires? Sharp!
Thanks, the front wheel is a dna fat 50 spoke and the rear is stock. They are both wraped in shinko 777hd ww. I have been looking at the mikuni 42, price wise i will either go with it or stick with my cv. It's still in the 70's in Ohio so far so I won't be tearing into it till the temp breaks. Also i noticed my block has a small leak at the split should i be concerned with this? Thanks guys.
Received 4,317 Likes
I guess the answer to your question is yes (although there are several other options out there).
Start a new thread of your own, there's a good chap. This one is about engines and your query will get lost in here. As Texas says, there are solutions available.
