HELP! cam came out with nose cone
Hi, I was changing the cam in my 99 fatboy an when the nose cone came off the cam came out BEFORE i could rotate the motor an line up the timing dots. I can not see a timing line/dot/mark on the crank! I thought I saw one, put it together an it won't run. runs a little then massive backfire. I know my eyes aren't what they used to be but I even had a magnifying glass looking that crank over. any pointers appreciated!!!
Received 4,317 Likes
The "mark is not on the crank but on the pinion gear itself. Look for an engraved line BETWEEN two teeth. Line that mark up with a similar engraved line on the cam. There will be a dot on the cam at the 8:00 position. That dot lines up with the mark on the breather gear.
Received 19,523 Likes
