Evo rebuild underway...
Old 11-12-2015, 05:42 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
Default Evo rebuild underway...
Okay, it's not winter yet but I'm done. Started to break down the bike, motor almost ready to come out,saved the ignition for last thing before the motor mounts. Here is first pic, what am I looking at here, original ignition ?
Old 11-12-2015, 05:59 PM
glidein wide
Old 11-12-2015, 06:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,809 Likes on 3,314 Posts
Yea, Looks original. I like the way the cam and pinion journals look like. Still the original breather gear as well. How many miles? Good luck with the build.
I myself will be ripping the heads off this weekend and sending them back upstate. It's time.....
Old 11-12-2015, 06:14 PM
traildog's Avatar
traildog
traildog is offline
Good luck with it glidin! I miss the wrenching...........
Old 11-12-2015, 07:00 PM
glidein wide
Has about 40 K miles. No turning back now ! It's a first for me. Done for the night, cam still in but I think I saw some wear on the first lobe and the roller for that lifter, I will post when I get there.
I have to create something to bolt the motor to and mount on my bench, some kind of stand.
Old 11-12-2015, 07:03 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
How long did it take you to get to this point? Looks like you are well on your way!
Old 11-12-2015, 07:24 PM
glidein wide
I did a little yesterday, most of it today with a lot of screwing around in between.
Maybe about five hours or so.
Anyone know what the red dots are on the cam gear ?
Old 11-12-2015, 07:47 PM
Anthony Paul's Avatar
Anthony Paul
Anthony Paul is offline
Check these guys out. They got some good stuff for the evo still. I got my 83 cu in kit for 550 last year and and that is with all gaskets.
http://www.hastingsmotorcycleparts.com/main.sc
Old 11-12-2015, 09:12 PM
apples402's Avatar
apples402
apples402 is offline
You gonna crack the cases? Just wondering about removal of engine complete.
Old 11-12-2015, 09:42 PM
98hotrodfatboy
Yea, it's a stock HD cam. If you look on first lobe facing the inner cam bearing you'll probably see the letter N, it designates the grind.
Quick Reply: Evo rebuild underway...
