Brake fluid mess up
Old 11-13-2015, 05:01 PM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
Default Brake fluid mess up
I messed up! I bought a set of chrome controls (drag) part number 0610-0532
I thought my old master said dot 4 but it really said dot 5, So i installed the new master (drag part) and the cover on it said to use dot 4. which i filled with dot 4. I only took the line off the old master and attached it to the new and filled it up.
So i'm sure there is no dot 4 down to the calipers. Can I just take the master off and clean it and flush the lines to the calipers with 5 by unhooking them. What concerns me is the new master says dot 4 , can 5 be used in it?
Old 11-13-2015, 05:08 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,537 Likes on 3,789 Posts
You need to flush thru completely with a couple bottles of 5..Just my opinion.
Old 11-13-2015, 05:34 PM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
Do you think its OK to run DOT5 in a master labeled as DOT4
Old 11-13-2015, 05:38 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
I've heard denatured alcohol works well as a flush when going from 4 to 5.
Old 11-13-2015, 05:39 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
Should be fine.
Old 11-13-2015, 05:51 PM
Ruggs59's Avatar
Ruggs59
Ruggs59 is offline
Thats good to hear, Guess its time for some braided front brake lines. and flush the new master good...
Old 11-13-2015, 05:57 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,344 Likes on 1,550 Posts
Seriously. Flush it, run 4. Cheaper and you will never realize the benefits of 5 on your Harley, that's why they went back to 4.
Old 11-15-2015, 06:26 AM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,704 Likes on 1,989 Posts
Sure, because DOT 4 is a much better paint remover than 5.
Old 11-15-2015, 06:40 AM
Jackie Paper
Why they went to DOT 4 across the line of bikes was because some got ABS a few years ago and it requires DOT 4 since ABS was designed around the automotive system and DOT 4 is used.
DOT 4 sucks big time in the front master cylinder when the bars are over the tank if a problem in the system should occur.
There is a difference in the rubber in the two system and if you got a DOT 4 master, you should get the proper one.
Old 11-15-2015, 07:30 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,495 Likes on 4,612 Posts
As long as you are the only person who services the bike.
I`ve been using DOT 4 in my `89 Softail for at least 20 years.
Quick Reply: Brake fluid mess up
