Got bike apart need input *pics*
What bike are you talking about? I checked your profile and all I saw was a 96 FatBoy. That's a top breather engine.
The EV46 would be a good cam for that bike, but if you wanted to go a bit lower in the rpm band, the EV13, EV23, or EV27 would be good selection in Andrews cams. I run the EV27 in my 93 FLHS and it did wonders for the overall performance of the engine. It works great solo or two up loaded to the hilt.
Here's the quick chart from Andrews:
http://www.andrewsproducts.com/sites...014-page13.pdf
Check into other cam manufacturers, as there are a few guys running cams from Woods and others.
Thanks. I know it was kinda a dumb question but just want to know all I can.
Thanks bagger!
Thanks bagger!
Received 4,317 Likes
When they first came out S&S said they were for 70-99...after a while they changed it to 93-99...there is a reason the manufacturer does not recommend them for bottom breathers...plus add the fact of many horror stories when the reeds break off. Pretty simple to have the bore oversized and use a regular breather.
Ok so got everything to the builder. He's going to bore cylinders .05 over and is recommending 10:1 wiseco forged pistons and cometic gaskets. He says this is a good reliable combo with my EV46 cam and I won't have any problems on pump gas (91 octane here in cali). With this combo and stock heads will the compression actually be 10:1? Tried to use the calculated on big boyz site but I got lost trying.
Oh and whats the compression # that is most important, static or dynamic?
One of those gray areas about the s&s reed breathers that I have always been interested in.
I know integral engine components are different than superficial accessories but many parts work for more applications than the manufacturer specified.
Today I know of more than a few guys running s&s breathers in bottom breathing motors. Fwiw I replaced my nylon gear in my 1998 fltr.
