gas smell
Had a bike that each time I rode it I would smell gas when stopped and also on my pants.Never a drip..Turned out to be tank rusted and gas seeping out a tiny pinhole at such a slow rate it evaporated as it came out.Drained tank and was able to push a probe right through tank.I found a new tank.I hope this is not your problem,but I always seem to have oddball (A$$hole) problems no one else has...
some mothers wheel polish on it and spin it with my fingers to remove the
corrosion from the float jet. Also inspect the rubber on the needle valve
under a big magnifying glass.
Check if there's any rotten vent lines #25, and if the vent/vacuum cap is working, and that the cap is sealing to the tank #13
http://www.stcharlesharleydavidson.c...98B%5cT52%5cGH
