Fast Idle RPM with Enricher
Old 02-28-2016, 06:09 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
Default Fast Idle RPM with Enricher
Can the enricher be adjusted to increase the idle speed at cold start-up? With my enricher pulled all the way out, it idles at 1000 rpm, same as my warm engine idle speed. Fast idle spec in the manual says 1500 rpm. I just dont see any way to adjust it.
Old 02-28-2016, 06:18 PM
glidein wide's Avatar
glidein wide
glidein wide is offline
My cable has a boot over the adjustment, pull it back and make sure chock closed at full pull.
One click inward idle increases to around 1500 rpm... Should only be left on for thirty seconds anyway, close choke and lock throttle at1500 to warm up...
Old 02-28-2016, 06:54 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
I dont see the "click" you are referring to.
Old 02-28-2016, 09:23 PM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
My CV does the same ****, usually in the summer time it will get its *** on up to 1500 right away with the choke on. I really only grab the choke to get it started, and close it and hold the throttle at 1500 within the first 5 seconds.
Old 02-29-2016, 10:25 AM
0maha's Avatar
0maha
0maha is offline
Received 4,668 Likes on 1,660 Posts
That's exactly what I do. And mine really only wants the choke on cold mornings.
Pull the choke, thumb the starter, hold it at 1500 ish while slowly closing the choke. Spin the little wheel to hold her there while I gear up, then we're rolling.
Old 02-29-2016, 10:27 AM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
I do the same thing but, I think it should idle faster with the choke pulled than it currently does.
Old 02-29-2016, 01:05 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,324 Likes on 1,948 Posts
If it starts and you can idle up with the throttle then set the throttle lock I don't really see the problem.
You want the choke on as little time as possible.
emperor wurm
12-08-2011 10:08 PM
Bengo
11-21-2009 08:21 PM
ofuzz_2000
11-12-2009 02:18 PM
Electra1
06-23-2008 01:09 PM
SKJOLD
VRSC Models
04-18-2007 06:57 PM
Quick Reply: Fast Idle RPM with Enricher
