Wilwood GP310 Calipers
Just bought a pair in black for my twin disc conversion, see what ya mean about the bleed screws, was figuring to bleed em off the bike suspended higher then master cyl, I've done this many times with sports bikes, use a piece of angle iron same thickness as disc, bleed em though and yr done
08xl1200r (01-22-2024)
That's the main reason I went with the PM brand.
I was new to disc brakes on 2 wheels & wanted to start out moderately.
But after having the PM ( rated # 2 behind Wilwood) if & when I get another bike, Wilwood will be going on.
Don't get me wrong the PM are plenty.
Grab a handful you better be ready. But I would like to try the Wilwood.
Ride Safe,
Harold
From what I have read & researched, the Wilwood are about the most aggressive calipers , out there.
Ride Safe,
Harold
Ride Safe,
Harold
I had a wilwood dual piston on the rear of my rigid for years and that thing worked awesome. That being said I have a performance machine four piston differential bore caliper on my softail right now and that thing stops! Both brands are serious improvements over the stock shitty oem calipers
