Newer Brembo calipers on a evo glide?
Old 04-08-2016, 03:38 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
Default Newer Brembo calipers on a evo glide?
Anyone tried this yet. I wouldn't mind the extra stopping power. Looks like guys have used it on 2000 and up baggers but no one is coming foward with info on evo baggers
Old 04-08-2016, 04:10 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Owtlaw just put some on his FXR.
Old 04-08-2016, 05:28 PM
Bumpandrun's Avatar
Bumpandrun
Bumpandrun is offline
It's pretty simple swap. Newer lower legs so u don't use adapters( legs cheap on eBay 50 bucks) there are bearings u can buy to keep your 3/4 axle if u want
11.8 rotors. See how u like it. If u want to go a bit more change out the master in the bars. Take off lines,calipers,rotors and legs should only be 250- 375 bucks. Sometimes all new as guys switch out for chrome at delivery. Need to put a small notch in rotor for speedo drive. Easy with a small file. Big big difference in stopping
Old 04-08-2016, 05:49 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
Lots of threads already on this one.
Brad,
If you're gonna use the 19" fxr wheel, from your other thread, then you will need a different mix of spacers. The hub is thinner than your current glide wheel and then you w would most likely need to re-shim the calipers.
Good luck and document it for the rest of us.
Tom
Old 04-08-2016, 07:08 PM
brad75raiders
I decided against the 19 fxr because of the flh weight. I am now looking at the enforcer rim...
Old 04-08-2016, 11:11 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
Not Brembos, just the 4 pot HDs, 2000 to 2006. Brembos require a different disc, I think. The HDs stop better than I can use.
Old 04-09-2016, 03:35 AM
Spanners39's Avatar
Spanners39
Spanners39 is offline
You don't even need the rotors and legs as you can buy adapter plates. I have 1994 Honda Fireblade calipers (cheap as chips from a breaker) and Harley aftermarket 330mm rotors, they'll out stop even the 4-Pot H-D ones.
Kees used Yamaha calipers on his stock rotors and made up his own brackets.
Old 04-09-2016, 07:13 AM
texashillcountry
Dirt don't hurt
Oops my bad.
Old 04-09-2016, 07:58 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I have Brembos and later sliders for my 1990 Glide. The sliders were cheaper as secondhand take-offs than adapters! Adapters are available for some Jap calipers.
Old 04-09-2016, 09:55 AM
Bumpandrun's Avatar
Bumpandrun
Yep as was said the lowers are way cheaper. Everybody has to have chrome and most are switched at dealer. Seen new ones from 35- 55 a set. Not worth screwing with miss matched parts when u can do bolt ons now. Brembos are cheap now. EBC. Pads I paid 27.00 bucks the other day. Plus no screwing with brake lines . It all bolt on.
Quick Reply: Newer Brembo calipers on a evo glide?
