Street Glide wheels on a 98 Road King?
Scootertrash60 (04-28-2016)
If you have the big thick iron rear rotor, it isn't a simple mod IMHO. The SG came out some time later, using the later style smaller rotor and caliper. I don't have an SG rear, but I do have a wheel and brake from that later era, on my 1990 bike, which I achieved by swapping the swingarm, brake etc.
This I know. My question pertains to other issues involved with the swap, mainly if the wheel is wider due to the buffer between the sprocket and hub, which it appears to be judging from Mr Brown's post. Unless there is another reason for swapping the swing arm out.
I've been doing all the work on my Harleys since '85, save for porting and bottom end work. More than "some work" isn't an issue for me. I enjoy the challenge, honestly. For me that's what Harley is about. Any RUB can buy bol-ons and pay someone to do it.
Thanks for the replies gents!
Cush drive rear wheels wont fit, you need a '07 and earlier SG or RG wheel.
Look at 2000-01 touring models which has the same axle and swingarm as yours and sealed wheel bearings,
the bearings, middle and outer spacers should work in the SG wheel.
You could bore the ID of your pulley and use it, or get the correct one.
not sure about your brake caliper, if you could find a '00-'01 caliper, it would be a nice upgrade.
http://partsfinder.onlinemicrofiche....0AND%20SPOCKET
http://www.jpcycles.com/product/202-182
Scootertrash60 (04-29-2016)
If you are concerned about the different axle sizes, i found a machine shop in New Hampshire that has machined adapters. Found them while looking for compression releases...
Motorway Engineering. Manchester New Hampshire....here is their link.
http://vulcanworks.net/store/Wheel-B...mm-to-3-4.html
