Cigarette lighter and hidden antenna install...
I just received a Boom Audio powered antenna (new) with no instructions and a cigarette lighter (used) from an old inner fairing a buddy of mine purchased. I drilled the mounting hole in the fairing, hooked up the leads and the radio and lighter work great with the ignition on but while in Accessory mode I have no power to the lighter.
Inside the fairing there are 5 connector points with 2 attachment spots on each. I seem to remember my Buddy's was hooked up to the front screw on the far right when looking at the fairing from in front of the bike.
Is this the right spot to wire from? I checked my manual and searched posts here in the forum and couldn't find anything on it.
Thanks for any help...
Glenn
Glenn
Received 4,317 Likes
Another question though... does the cig lighter need to be grounded if mounted in the plastic inner fairing? I temporarily ran a ground from the lighter ground to the back mount on the stereo. The Boom Audio has a hot and ground wire which I connected to the lighter hot and ground. Reception seems to be pretty good. Picking up a classic rock station from a town about 45 miles away while the bike is sitting in my shed,
It's not that I need power to the lighter while the ignition is shut off, I just thought that it should be powered with ignition on and in accessory mode. Checking to see if I had it connected right or not.
It really doesn't matter where you run it as a Harley is a 12 volt system.
Meaning if a spot is hot it is running 12 volts.
Yes you need a ground.
All electronic circuits require a power source and a ground.
I ran mine to the battery just because that was easiest for me.
Blackstar (05-04-2016)
Then find a spot that is hot in accessory mode.
Thanks for the quick replies guys. Greatly appreciated. I just need to pick up a couple more heavy duty connectors and I'm good to go. Heading to work now for the evening shift and will check back in tomorrow with my final results...
Glenn
