My $130 front brake upgrade
bracket $44
caliper rebuilt kit 15
longer brake line 53
new pads 16
I have a 99 Fatboy an wasn't a big fan of the single piston front caliper. I hadn't had a problem stopping but haven't had to panic stop either. I had a pair of 4 piston calipers off the front of an 05 Electra glide I had laying around so this made sense to do. I rebuild the caliper since it had dot 4 in it an turns out it was a little grungy. Got the mounting bracket off Amazon, some decent pads an the required longer brake line off eBay. Stops much better now.
I thought about doing the Wilwood front caliper for around $215, might not have needed the longer brake line with it, but I know it will be no problem finding pads everywhere for this one. I didn't add in the $10 for a bottle of dot 5 brake fluid since the old fluid was yellow an nasty an in need of change anyway. Gonna have to do the fluid for the rear next.
The mini vac was VERY handy for this job. Don't know if I could have filled the empty brake caliper an line without it, plus I was doing this alone.
new pads 16
Received 4,317 Likes
Nope only one leg and no axle change. When it's single side brake.3/4 ....1 inch and 25 mm all the same on left side except brake mount
u just need one leg . The left side the axle is the same . Than u can run brembo or the older one like you have. It's one of the best braking upgrades u can do. Bet u were surprised the first time u used em.... Lol
A bit more than just a different right lower leg and right caliper
MEDEVAC247
01-13-2014 07:11 PM
