New clutch cable adjustment issue, loose
Old 05-22-2016, 08:43 PM
Chris Sigo's Avatar
Chris Sigo
Chris Sigo is offline
Originally Posted by 0maha
Just to clarify, you are installing a new cable (with new cable sleeve), correct?
Correct, all new cable assembly. I bought the bike in non-working condition, so i can't speak to how the foot clutch setup performed before that. I did have the tranny looked at by a shop though, and had a new clutch hub installed. They didn't find anything else wrong on the clutch side.
The tranny pushrod has a flat side that doesn't seem to lock in anywhere, is it supposed to? Trying to eliminate possibilities.
I can seriously back the cable aduster completely off the threads with NO change in tension. This is AFTER I adjust the clutch. Probably a user error but i haven't found it yet.
Old 05-22-2016, 08:50 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,892 Likes on 3,007 Posts
Originally Posted by TSheff
Adjust the clutch - per procedure - cable completely loose, screw in until you feel tension - back off 1/4 to 1/2 turn - lock the screw down. Obviously the transmission side cover has to be on. Then adjust the cable until you have 1/8" free play.
Was the clutch working before, if so that shouldn't be a problem after it is adjusted properly? If you are moving it back to the hand do you have the correct/stock lever perch bracket? Cable lengths are for shorter or taller bars, the amount of adjustment range should be consistent.
I think this is where your error is.
Old 05-22-2016, 11:31 PM
Chris Sigo's Avatar
Chris Sigo
Ranger, can you shine more light on this? I did the clutch adjustment per spec several times: loosened the lock nut, found the point of tension with an allan key, then back off 1/4 turn. Tried it again at 1/2 turn. Then just for the hell of it tried it at the point of tension to see if i could get some feel in the clutch lever.
I did this every tine with all full slack in the clutch cable, then backed out the adjuster nut (after clutch adjustment) hoping it would take up cable slack. Thanks
Old 05-23-2016, 06:58 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
Chris this is the only thing I can think of at this point.
On my clutch hub there is a point when I'm turning in the clutch adjuster that it binds up for a second giving a false feeling that it is seated, I have to turn past that point to really seat the adjuster.
That maybe what you are experiencing.
Old 05-23-2016, 05:22 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
In your picture it looks like your turned in to far.
I did this too.
loosen the cable, back out the center bolt then slowly tighten it until the allen key will "hang" and not fall clockwise under it's own weight, that's the tension spot. then back off 1/2-3/4s of a turn.
Ridr (06-05-2016)
Old 05-23-2016, 05:51 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,515 Likes on 3,772 Posts
This is probable your problem. if you do indead have the proper cable. That fine thread nut is very easy to over-tighten and burr the threads. Extend the cable out at the lever so you can get some movement at the clutch. Now while squeezing the lever and releasing, turn the adjuster in on the clutch till it takes all play and then in two or three more turns. That is how you deburr it. However, when I look at your picture with your adjuster all the way in, it appears something else is wrong.
Maybe the cable is not correct with the steel cable being too long for the sheath. The adjuster screw has been modified or the push rod is bent. Remove the snap ring and pull out the adjuster and pushrod and check the ends. Could be your throw out bearing?
However, I have see the same thing over and over on here and it's simpley burrs on the clutch adjuster.
I know the instructions also say loosen the cable all the way before adjusting. This 90% of the time makes so much length, you cannot tell what you are doing. Only lengthen cable for a little free play. If you have a little, that's enough. Then deburr and set.
Old 05-23-2016, 06:01 PM
brad75raiders's Avatar
brad75raiders
brad75raiders is offline
I did this one time and could not get my clutch to produce any resistance racked my head over it. Turns out my dog nudged the clutch pushrod under my garage shelf...........
Old 05-23-2016, 06:06 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
Your clutch is adjusted way too far in for one thing,.
Old 05-23-2016, 06:17 PM
texashillcountry
Dirt don't hurt
I thought so too at first glance then I realized he is not using the OEM locknut.
He is using a standard nut which is a bit thicker than the OEM locknut.
Old 05-25-2016, 07:03 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,340 Likes on 1,548 Posts
Progress report or findings?????
xskuzame
10-06-2014 09:12 AM
Northern Glide
03-03-2013 12:17 PM
barnzee
07-04-2011 11:40 AM
Dieselhed
08-09-2009 06:12 AM
skos
10-23-2008 03:46 PM
Quick Reply: New clutch cable adjustment issue, loose
