'95 FXDWG - Eerie Random Engine Noise
Some people call them tappets , some call them lifters , some call them cam followers , I've been a Mechanic all my life and called them all of the above at some time or another. The term cam follower is certainly not exclusive to overhead cam engines.
Received 4,317 Likes
I apologise for the misunderstanding.
The British call lifters cam followers , they have odd names for lot's of things, like , the hood on a car is a "bonnet" or , a wrist pin is a " gudgeon pin".
I've seen lifters listed as "cam followers" in more than one catalog.
They also drive on the wrong side of the road....
I've done all kinds of wrenching, fabrication, machining, but this is my first HD. I do have the service manual as well, but it's always nice to have some experienced guys filling in the gaps and helping to fast forward diagnosis etc.
I had a little time this morning to fire up the bike. Checked all the exhaust flanges, nuts, studs, clamps, etc and they all looked good. Then while the machine was idling, I started feeling the pushrod tubes and the furthest one rearward was vibrating whereas the other three were not.
I then focussed my attention upwards following the noise to the rocker/valve cover area and am pretty sure that's where the random noise is coming from. It sounds rocker arm/valve spring-ish....again, it is not a constant ticking sound, it's totally random, comes and goes, just making one click.
I suppose first thing Sat I'll crack open the rocker cover and inspect that. I've attached a picture of the push rod. Again, the bike is a 1995 - are these stock or aftermarket rods? Seems to me stock pushrods in the manual look non-adjustable.
Let's see where this goes now...thanks guys
Definitely not stock.
Probability is that your pushrod is bent.
