Fuel inlet replacement on bike?
Old 05-25-2016, 11:45 AM
0maha's Avatar
0maha
0maha is offline
Received 4,667 Likes on 1,660 Posts
Originally Posted by kp877
Went to the dealer they didn't have the inlet and couldn't tell me when they could get one. Odd. They had the carb manifold seal so grabbed one. I didn't even bother asking for the plastic cover. Went to the Indy they had the drag specialty inlet so I bought it but noticed the corners aren't flat like the HD or CVP version. Hope it goes on straight and doesn't try to go crooked.
There is more taper on the end of that than there is on the OEM unit. Should help you get it started straight. Go easy and I'm sure you'll be fine.
Old 05-25-2016, 04:26 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 1,726 Likes on 924 Posts
Yes, that one will work fine. Use a little blue Loctite on it to help it press in easier and seal. Remember to put the barb (part the hose connects to) end of it at the correct angle. Just duplicate the angle of the old one. YD
Old 05-25-2016, 05:19 PM
br549A1's Avatar
br549A1
br549A1 is offline
Loctite blue? I was thinking some green since its sleeve retainer but I never checked to see if either were gas resistant.
Old 05-25-2016, 08:20 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
Put it in the freezer for a few hours too. Goes in easier. I didn't use any loctite, and it's fine.
Old 05-25-2016, 08:24 PM
Yankee Dog's Avatar
Yankee Dog
Green, blue, red, don't matter. Really not needed, but as mentioned, helps it press in a little easier and ads a little extra sealant. YD
Old 05-25-2016, 08:45 PM
89FLHTC's Avatar
89FLHTC
89FLHTC is offline
Smart idea!
Old 05-26-2016, 04:36 AM
br549A1's Avatar
br549A1
br549A1 is offline
Got it installed last night. It didn't want to go straight at all. I ended up holding it and tapping it in. I tried c-clamp and vise. The inlet is not square on the end and it would twist under even the lightest pressure.
Thanks for the help guys. Wonder what will break next
Old 05-26-2016, 04:52 AM
Hackd's Avatar
Hackd
Hackd is offline
Wonder what will break next????
Well.... Since you're asking to receive The MoCo curse: An obscure, small, and inexpensive part will break. The repair will require you to first remove a number of perfectly good expensive parts, necessitating purchase of a number of expensive gaskets/seals to re-install. In the process of doing that, you will damage one of the expensive parts, necessitating another trip to the stealer or indy, which probably won't have it. And when attempting to search for said part the internet will go down until Monday, but since Monday is a Holiday, none of the vendors will be able to ship the needed part until Wednesday or Thursday. Shipping cost will be almost as much as the needed part, and there is no telling when it will get there. Then UPS looses/damages the part in transit.
Just trying to help....
Old 05-26-2016, 04:57 AM
br549A1's Avatar
br549A1
br549A1 is offline
Originally Posted by Hackd
Well.... Since you're asking to receive The MoCo curse: A small inexpensive part will break, that will require you to first remove a number of perfectly good expensive parts, necessitating purchase of a number of expensive gaskets/seals to re-install.
That's exactly what just happened when the inlet cracked. Actually it's not back together yet either. One o-ring for the backing plate fell and after 30 minutes of searching the engine and garage floor I quit and will just get a new one at the hardware store later today.
Old 05-26-2016, 05:13 AM
Hackd's Avatar
Hackd
Hackd is offline
That's exactly what just happened...
The Curse. Don't ever doubt the power of The Curse.
Quick Reply: Fuel inlet replacement on bike?
