Truing a Connecting Rod End - Ideas
Have a look at my other threads for all the fun I've been up to as a new Harley owner...
So the motor is completely apart now, crankshaft runout is within tolerance, but the rod end on the busted piston is definitely bent. Not twisted, but bent. Thanks for the heads up from a couple members of this board to check for that.
My question is, has anyone ever trued up a con rod end while it's still in the crank assembly. I'm sure if I just went at it, I'd take the crank out of true, so I am thinking about fixturing the whole assembly on the bed of my mill and locking the rod in place separate from the rest of the assembly (while it's sufficiently supported) and then making a tool to bend the end back into shape. I may even be able to set it up in such a way that I could use a hyd jack to gently bend it.
Don't tell me I'm nuts, I know that already.
I can't justify a proper and pricey rebuild, so I am getting creative.
Received 19,615 Likes
no evo rods can be rebuilt but the rods from japan ( RPLS ) is casted in them are cheaper to buy new and they come with a fitted crank pin and all the parts than fixing old bent rods, is no longer smart thing to do
i have put in hundreds of sets of them almost every year for 20 plus years and never had one set become a thing
But this is insane.
Seems to me what you need to do is find a shop that has the rod you need. I'm sure with a few hours of calling around you could find one.
If it can't be done with an Evo rod than so be it.
Yes I have seen the replacement rods with bearings and pin, I was hoping to make this happen in house to save some time and money as I can buy a rebuilt engine here locally for $1500. I've been quoted some crazy numbers for disassembling the crank, reassembly, and balancing, not to mention scheduling delays.
