Compensator/Crankshaft Nut Evo I/II
Hi! Itīs been a long time since last post...and I have no good news from the bike. I started to use the FLHC and a strange noise (tac, tac) started in the engine. I was driving far from home and I had no options...so the noise became louder until the engine stopped (200kms) The piston broke inside the front cylinder. You can imagine the end of the story. Damages: crankshaft, rods, piston, cylinder, head...
So I bought a new (1000kms!) engine. The problem is that my bike is a 87 model, and the engine is from 1996. I have seen that there is some different parts here and there that I need. But I have one question about the compensator nut fitting. Do I have to put a new nut (40392-91) or my old big nut (40392-70) will fit? I donīt want to force the threads...
Thank you!
Thank you!
40392-91...if you have an aftermarket stator cover...they come with a spacer that with work with either one...same thing applies to the shaft extension which must match the nut you use...confused yet?
chevdude
05-29-2017 07:19 PM
